artspolice
Sep 07, 2021Aspirant
Cannot log in to Netgear Genie from iPhone
I can't log in to Netgear Genie from my iPhone SE, using either "password" or the password I created. I've had more trouble with this app than any other on my phone. Netgear support has expired, so a...
- Sep 08, 2021
I really appreciate your reply. After I posted I reset the router and that solved the problem. I apologize for the false alarm.
artspolice
Sep 08, 2021Aspirant
michaelkenward
Sep 08, 2021Guru - Experienced User
No problem. Your question may well help someone who turns up in the same boat.
Glad it worked out.
