chrisowen's avatar
chrisowen
Cannot login to AC2300 router
2 days ago I bought a used router, a NETGEAR Nighthawk AC2300 Cybersecurity Dual-Band Wi-Fi Router - RS400-100NAS. and I have been trying to login since then. Insane isnt it. I have been doing this ...
  • chrisowen's avatar
    chrisowen
    Oct 26, 2021
    I did the full factory reset. Then I again used my Dell work laptop to access the login page with a LAN cable.
    I used IPCONFIG to find and try all the IP Addresses.
    Then I tried all the IP addresses also routerlogin.net, also tried both chrome and edge also turned the firewalls off.
    Not one of these things would allow me to connect to the router.
    In desperation I took the whole upstairs setup apart and brought it downstairs to my personal desktop.
    192.168.1.1 connected immediately.
    It forced me to change the password, I really wish it hadnt because I have a memory like a sive and I am old.
    How are my family going to access it? Presumably a factory reset will reset it anyway, so what is the point of it?
    I was then able to change the default wifi passwords, turn off the guest account and confirm auto update is set.
    Now I am going to give my work IT dept a piece of my mind. I wasted 3 days on this nonsense.
