plesifaf7
Mar 23, 2024Aspirant
Cannot login to router through PC browser
I can login to my router through the phone app but when I try to login through a browser it tells me wrong username or password. I've tried multiple browsers but no luck. I'm trying to set up a 3d printer with a static ip but can't see any way of doing it through the phone app. I've also contacted Netgear but that was a waste of time. I have a Nighthawk AX6 CAX30
1 Reply
Tried a different browser?
How are you trying to get in? Routerlogin.net or the IP address?
I have a Nighthawk AX6 CAX30That is a cable modem/router. The default IP address should be 192.168.1.1
I'm trying to set up a 3d printer with a static ip but can't see any way of doing it through the phone app.This is not something that you can do on the App.
Then there is the idea of setting a "static ip" address. You don't do that on the router either. What you can do it to set a "reserved IP address" in the router. Or you can use whatever software comes with your printer to give it a static or fixed IP address.
