Bosse1
Nov 09, 2020Aspirant
Cannot not stream Netflix and Hulu through switch GS116v2
The network(wired) setup is cable modem CM1200 (Firmware V1.02.02 a newer version is available but ISP GRANDE say they don't have or don't update firmware). Wifi Router RAX80 (Firmware version V1.0.3...
Bosse1
Hi GURU,
answers to your questions;
1. Yes, DG2470A is a modem/router combo.
2. Yes only the RAX80 is connected to the top port.
3. Direct connection RAX80 to TV doesn't work either.
4. Yes, TV's streams over wifi.
Regards Bosse1
Nov 09, 2020Guru - Experienced User
No other devices have issues?
Just the one TV?
And other devices can use the same ethernet port without issues?
Was it somehow blocked through access control?
Have you tried a factory reset and clean reinstall (not from backup) on the RAX?
- Bosse1Nov 09, 2020Aspirant
All TV's doesn't work. When trying to connect the TV's to wired connection it states there is no internet connection, but as stated before this doesn't happen when using the Arris cablemodem/ router. I can get internet through the TV ethernet jacks using an old Dell laptop with WIN7 operating system, same applies to all jacks on the switch.
When it comes to access control I have not adjusted anything and didn't see anything about this in the nighthawk app on my cellphone.
I don't know how many install I done using the nighthawk app but it's several and have also done several reset back to factory settings. The only change I've made was to change router login password.
I've read that there is ways to set a designated channel for 5G and turn off AXA 6 gig, but I have been able to find this.
I'm not very good at this, the only thing I know is that signals from RAX80 and the Arris must be different. The easy way out is to revert back to Arris and return the Netgear modem and router but I hate to give up so I will try and get it worked out. Have until Jan-2021 to get this resolved.
- plemansNov 09, 2020Guru - Experienced User
If the tv's are hardwired into the router, it shouldn't matter wireless AX on or off.
And its odd that everything works except for the tv's.
have you checked with the tv manufacturer's?
