jonnyhawk
Dec 22, 2020Follower
Cannot obtain IP address
When I check the status of the network port, the Network Icon shows the inactive status. The system warns that the IP address cannot be obtained from the server. Is the DHCP service on the server d...
michaelkenward
Dec 22, 2020Guru - Experienced User
What network port? One on the router?
Where do you see this icon? On a Windows PC?
Is the DHCP service on the server disabled?
What system is this? What shows this warning?
- timberlandMar 21, 2021Aspirant
