media601
May 24, 2016Aspirant
Cannot print after connecting Nighthawk R7000 to HP 6940 via ethernet only
I set up a new R7000 two days ago and automatically applied latest firmware. I cannot print to my HP 6940 Deskjet anymore. The printer is ethernet only--no WIFI. The printer displays in the attached ...
- May 24, 2016
Thank you for the replies. Netgear email support led me to discover the printer port was still pointing to the old IP. I was not able to change the config, but was able "add a new printer". I selected the same printer and selected "do not use existing driver". That worked and printer port is now pointing to correct IP. Thanks to Vidhya (Expert ID: 1610).
media601
VE6CGX
May 24, 2016Master
Good for you. Now you can assign that ip address to the printer for good from router. That way you always know where the printer is.
