bman2021
Feb 12, 2021Aspirant
Cannot reach Comcast internet speed with AC2300 (less than 25%)
Hello NetGear Community - I'm having trouble with the R7000P reaching wifi speeds which I have piped into my home (1Gps through Comcast). My modem is an Arris SB8200. Confirmed that I do have 850 Mb...
bman2021
Feb 13, 2021Aspirant
Thank you very much! Do you have a recommendation that could hit the speeds closer to what I'm actually piping into the home?
Feb 13, 2021Guru - Experienced User
Its a struggle for AC devices to hit gigabit speeds. A few of the top end AC routers and wireless devices can but for the most part, they don't. AX is hitting gigabit speeds but it requires a AX router and AX device as well as halfway close distances to do so.
Is there a reason you're wanting gigabit over wireless? Most devices aren't going to realize much difference from 200mbps to 700mbps. Reason why is most things you do (streaming/gaming/etc) don't require a bunch of bandwidth. For example, 4k streaming only needs 25-40mbps but it needs to be reliable.
So its more about if all your devices can hit reasonable speeds versus can you get 1 device to hit gigabit.
