bman2021
Feb 12, 2021Aspirant
Cannot reach Comcast internet speed with AC2300 (less than 25%)
Hello NetGear Community - I'm having trouble with the R7000P reaching wifi speeds which I have piped into my home (1Gps through Comcast). My modem is an Arris SB8200. Confirmed that I do have 850 Mb...
bman2021
Feb 16, 2021Aspirant
Was able to hit great speed the past few days, now all of a sudden the router won't provide wifi. Shows secured, no internet, for both the 2.4 and 5ghz channels. I think the there's something wrong with the router itself, as I have confirmed 900mbps with my laptop connected directly to the modem today. I know this is a different issue than what I originally posted.
Feb 16, 2021Guru - Experienced User
What firmware version are you on?
- bman2021Feb 17, 2021Aspirant
V1.3.1.64_10.1.36
- plemansFeb 18, 2021Guru - Experienced User
so theirs both newer and older versions.
The newest currently is 1.3.2.134
the version I usually recommend if people are having issues with newer firmware is 1.3.0.20
I'd highly recommend any firmware change be done over a hardwired connection, once done, do a factory reset and clean install (not using a backup configuration).
