Damen
May 08, 2017Aspirant
Cannot see my netgear router R7000 network
Hello, Yesterday my netgear network disappeared. I can still see my BT wifi but none of my devices can see the netgear router. The usual array of flashing leds are all off with the exception...
- May 09, 2017
It is the modem you need to tweak.
You can probably find tips on this on the BT user forum.
For example:
Solved: Re: Configure Home Hub 5 as modem only? - IT WOR... - BTCare Community Forums
Damen
May 09, 2017Aspirant
Thanks for the reply.
Most strange it has started working again. I have now moved it away from possible small child interference though I am not convinced this is an issue but like to eliminate that potential 'failure mode'.
Hub is a BT homehub 5.
Now that I can see the netgear router and therefore talk to it I will bridge it.
Cheers
michaelkenward
May 09, 2017Guru - Experienced User
For example:
- DamenMay 10, 2017Aspirant
Thanks for the link Michael it is very informative.
Much appreciated.
- michaelkenwardMay 10, 2017Guru - Experienced User
Good luck with the Homehub. I don't like it. I use a Netgear D6400 modem/router on my main phone line.
