Headies
Jan 09, 2022Aspirant
Cannot specify port 65535
I'm trying to apply port forwarding to my gaming PC. It is hardwired to the router. When I go into port forwarding options for the router, it says I can only select ports 1-65534. I specifically need...
DexterJB
Jan 18, 2022NETGEAR Moderator
Hi Headies, the link below may help out.
https://kb.netgear.com/24290/How-do-I-add-a-custom-port-forwarding-service-on-my-Nighthawk-router
Dexter
- HeadiesJan 19, 2022Aspirant
Sorry but this does not help. I know how to port forward, but my range of ports is limited (the max is one less than I want). Any reasons for this??
- FURRYe38Jan 19, 2022Guru - Experienced User
Does .34 work?
Possible that .35 is closed for NG routers for other purposes or uPnP.
Did you disable uPnP before configuring ports?
