phamtastiic's avatar
phamtastiic
Follower
Nov 29, 2021
Cannot submit a hardware replacement request
Anyone have any solutions for this? I've been trying to submit a case request for the past week and it won't submit and their number says to submit a case prior to calling. Should I just call the support line instead?
  • FURRYe38's avatar
    Try a different browser or PC to submit a support ticket. Or you can call in if you got the support number.
    You might reach out to a forum moderator for help and information regarding this:
    DarrenM
  • I couldn't either. I called and spoke to a tech support agent they opened the RMA request. Hopefully that helps.
