mckmck's avatar
mckmck
Cannot turn on Circle
I have not been able to turn on Circle for my router.  If I login via the Nighthawk app, there is no parental controls option.  If I login via the computer, the Parental Controls option is grayed out...
  • mckmck's avatar
    mckmck
    Jun 09, 2020
    Eventaully, with enough poking around, I found the solution.  Somehow the AP mode had been turned on and once I turned it back to router mode, I was able to enable Circle again.
    Also, the Nighthawk app may not "support" parental controls exactly, but it does have the option to enable/disable Circle under settings > parental controls via the app.  Once I corrected the AP setting, I could see the Parental Controls settings in the app again.
    No one replied in the Circle section but I will post this solution there in case it helps someone else.
