mckmck
Jun 07, 2020Aspirant
Cannot turn on Circle
I have not been able to turn on Circle for my router. If I login via the Nighthawk app, there is no parental controls option. If I login via the computer, the Parental Controls option is grayed out...
- Jun 09, 2020
Eventaully, with enough poking around, I found the solution. Somehow the AP mode had been turned on and once I turned it back to router mode, I was able to enable Circle again.
Also, the Nighthawk app may not "support" parental controls exactly, but it does have the option to enable/disable Circle under settings > parental controls via the app. Once I corrected the AP setting, I could see the Parental Controls settings in the app again.
No one replied in the Circle section but I will post this solution there in case it helps someone else.
mckmck
Jun 08, 2020Aspirant
Thanks for the response, I will try in the Circle section as well.
I understand that Circle and the basic parental controls are different. The only reason I mentioned it is that’s the screen where they are enabled let’s me turn the basic controls on/off just fine. But it will not let me turn on the Circle.
I am and have been using the Nighthawk app. According to all the documentation I can find, I should be able to turn on Circle there as well but I am not even getting the option described in the documents.
I have firmware version 1.0.11.100_10.2.100.
michaelkenward
Jun 09, 2020Guru - Experienced User
The Nighthawk app does not support Parental Controls. Never has. The loss of this when the Netgear mobile app died caused many complaints.
There is a separate app for Circle:
Circle | Product | Support | NETGEAR
Circle and Parental Controls are so different that there is little point in trying any comparisons between them.
The best way into Parental Controls is probably through OpenDNS
https://netgear.opendns.com/sign_in.php
This works on any device.
As I said, questions about Circle belong in the appropriate section.
- mckmckJun 09, 2020Aspirant
