brownbreadfox
Jul 12, 2021Aspirant
Can't access admin page for C7800
I can only access the admin page (192.168.0.1) after I reboot the router. How do I access the admin page without rebooting the router?
Jul 12, 2021Guru - Experienced User
have you tried going to 192.168.100.1
- brownbreadfoxJul 12, 2021Aspirant
Yea I've tried 192.168.0.1, 192.168.0.1.1, and 192.168.100.1
The address that consistently works after reboot is 192.168.0.1 and it is also indicated as the "router" in the network preferences.
- plemansJul 12, 2021Guru - Experienced User
Have you tried a simple factory reset and reinstall?
Yes, I've tried the factory reset and re-registering with the ISP (the ISP controls the firmware so can't do a proper reinstall)
