pstrisik
Dec 03, 2021Follower
Can't access devices connected to extender from main network
I have the R8500 and a D-Link DAP-1520 extender. All works fine except I connect to the router by wifi and can't see the computer that is connected to the extender.
Is this normal? If not, it maybe that this is a cheap extender without much for settings.
Looking for help solving this. If I need a new extender, what is recommended to go with this router (if that matters), or is a mesh network a better way to go?
A mesh system would be more expensive,so hopefully I can either make this one work in that regard, or buy another model that isn't too expensive.
Thanks for any input.
1 Reply
Something you might contact D-Link support about or visit there community forums.
