KILLJOY
Feb 01, 2016Follower
Can't access genie. Stuck in Bridged mode?
Backround: My Netgear Nighthawk AC1900 has been nothing but problems since I bought it. Constantly rebooting itself, kicking me out of games, off of Netflix, etc. I am running it with a Netgear DOCSI...
- Feb 01, 2016
If AC1900 is still on bridge mode check your main router UI for the IP (PC IP should be on that subnet too).
Else push the reset button until you see the power LED blinking amber (for 10secs at least) then wait till all the lights lit up normally.
Jatojumper
Feb 09, 2017Aspirant
Connect to the network with a static ip then navigate to your router ip address and you should reach the admin page. In bridged mode you still have full control over your wireless settings it's just a bit different to get to ...
