gen1sys's avatar
gen1sys
Can't access genie when router is in bridge mode
This is for R7000P, not for R7500 (couldn't select R7000P in the models)   This is my setup:   CompanyNetwork ----- wifi ----- R7000P in bridge mode ------- ethernet ------- laptop wifi is...
  • antinode's avatar
    antinode
    Jan 09, 2019
    > [...] I see in the network settings that the router IP is
    > 192.168.30.254 but entering that in the address bar gives a connection
    > timeout
       That router is, I'd guess, part of "[company wifi]", not your
    R7000P-as-bridge.  Your R7000P-as-bridge could have obtained an address
    from the DHCP server in "[company wifi]", but only that DHCP server
    could tell you which address that might be.  So far as your computer is
    concerned, your R7000P-as-bridge is transparent.
    > [...] What[']s the IP of the router?  If you are unsure, you can
    > verify it on the device providing DHCP (Domain Controller, Corp FW,
    > etc).
       Yup.  With no information from the DHCP server about its clients, you
    might have a load of address guessing ahead of you before you stumble
    onto the R7000P-as-bridge.
