gen1sys
Jan 09, 2019Aspirant
Can't access genie when router is in bridge mode
This is for R7000P, not for R7500 (couldn't select R7000P in the models)
This is my setup:
CompanyNetwork ----- wifi ----- R7000P in bridge mode ------- ethernet ------- laptop wifi is...
- Jan 09, 2019
> [...] I see in the network settings that the router IP is
> 192.168.30.254 but entering that in the address bar gives a connection
> timeout
That router is, I'd guess, part of "[company wifi]", not your
R7000P-as-bridge. Your R7000P-as-bridge could have obtained an address
from the DHCP server in "[company wifi]", but only that DHCP server
could tell you which address that might be. So far as your computer is
concerned, your R7000P-as-bridge is transparent.
> [...] What[']s the IP of the router? If you are unsure, you can
> verify it on the device providing DHCP (Domain Controller, Corp FW,
> etc).
Yup. With no information from the DHCP server about its clients, you
might have a load of address guessing ahead of you before you stumble
onto the R7000P-as-bridge.
gen1sys
I have this setup:
[Server without wifi card] --- long ethernet cable --- R7000P only air [company wifi]
on my mac with which I'm setting this up (wired to the R7000P and wifi disabled) I see in the network settings that the router IP is 192.168.30.254 but entering that in the address bar gives a connection timeout
antinode
Jan 09, 2019Guru
> timeout
> etc).
- gen1sysJan 10, 2019Aspirant
Thanks antinode, that was it! After I had the network administrator look up the mac address of the router in DHCP list, I could login to the router via that IP.
