Kendrite
Feb 15, 2020Aspirant
Can't access Modem/Router via WiFi
Recently purchased Nighthawk AC1900 and am trying to set it up. If I connect it via ethernet I can log into the modems login page but I can't via WiFi. I can connect to both the 2.4Ghz & 5Ghz...
- Feb 15, 2020
Edit: And now after changing nothing at all I can access the login scree via WiFi....shrug.
Kendrite
- michaelkenwardFeb 15, 2020Guru - Experienced User
Perhaps you just started the network in the correct order.
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it connect.
- Turn on computers and rest of network.
