Kendrite's avatar
Kendrite
Can't access Modem/Router via WiFi
Recently purchased Nighthawk AC1900 and am trying to set it up.   If I connect it via ethernet I can log into the modems login page but I can't via WiFi.   I can connect to both the 2.4Ghz & 5Ghz...
  • Kendrite's avatar
    Feb 15, 2020
    Edit: And now after changing nothing at all I can access the login scree via WiFi....shrug.
