Bogo
Jun 30, 2016Tutor
Cant access Nas with Ftp works localy to access nas with normal network
Whenever i try to connect to my nas with ftp i get error "ECONNREFUSED - connection refuced by server" when trying from my windows phone and disable the wireless so it gets an external ipadress it ge...
- Jul 04, 2016
Bogo wrote:
Edit:i have checked it all folders in the linkstation have have SFTP on
Ok, SFTP runs on top of SSH, so you only need to open port 22. You can close all of the other ports. You also need an SFTP client. Fortunately, FileZilla supports SFTP.
Needless to say, put a strong password on your NAS.
TheEther
Jul 04, 2016Guru
Try messaging one of the moderators (ElaineM, DexterJB). Maybe they can edit the post.
Bogo
Jul 04, 2016Tutor
yes now everything works on the pc (there is a protocall missmatch on the phones but that does not matter as the linkstations is quite old i kind of think i will not get the newest protocall
but using the last ports made everything works and just to make sure i have changed all password on the nas for added security. thank you for the help would given up a long time without it :)
