robweis62
Dec 01, 2021Tutor
Can't access netgear app on IOS devices
I have the Nighthawk X6S R7960P AC3600 Tri band router. I can access my account's control panel through a computer. I have two questions 1. for more than a year since I bought this router - I u...
- Dec 01, 2021
Netgear has set up a community forum specifically for the Nighthawk App product. Most of the people who watch that forum are more likely to have experience with Nighthawk App and know how to work it better than those of us who follow this "general router" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-App/bd-p/en-home-networking-apps
Thank you.
michaelkenward
Dec 01, 2021Guru - Experienced User
robweis62 wrote:
2. I wanted to run a firmware update as I'm on 1.4.1.68. From the control panel, I clicked on the firmware update. I clicked through the options and set off the install. The page just blinked the message "downloading and updating the language table, please wait for approximat one minute..." I waited 20 minutes and nothing happened. Any suggestions?
If possible avoid using apps to update firmware. Also don't use wifi unless you have to.
Experienced users prefer a manual update.
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
Be warned, though that the R7900P has had more than its share of firmware problems.
Search - NETGEAR Communities – R7900P firmware
No idea why you were told to "go away" and visit the apps section to fix this problem. Firmware is well and truly a router issue, best dealt with here.
- robweis62Dec 01, 2021Tutor
michaelkenward - thank you for your response to the firmware update. Knowing there are issues with the firmware update - i guess i will hold off. I will hold on to this for future updates. Thaks for the kind response
