robweis62
Dec 01, 2021Tutor
Can't access netgear app on IOS devices
I have the Nighthawk X6S R7960P AC3600 Tri band router. I can access my account's control panel through a computer. I have two questions 1. for more than a year since I bought this router - I u...
- Dec 01, 2021
Netgear has set up a community forum specifically for the Nighthawk App product. Most of the people who watch that forum are more likely to have experience with Nighthawk App and know how to work it better than those of us who follow this "general router" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-App/bd-p/en-home-networking-apps
Thank you.
Dec 01, 2021Guru - Experienced User
Thank you.
robweis62
Dec 01, 2021Tutor
Furrye38 - thanks for this pointer. Seems like a lot of people are having issues. I guess i will wait for a fix. Thanks for putting my mind at ease!
- FURRYe38Dec 01, 2021Guru - Experienced User
Hopefully NG will get things fixed.
You can reach out to NG support as well to let them know about what you experience as well.
