IkeM
Nov 13, 2023Follower
Can't access Nighthawk X6 R8000 (AC3200) configured as access point
I've added my router to a DSL modem/router to use as an access point. I can no longer access or log in to my router. I tried using the Nighthawk app but it does not let me log in. I tried logging ...
Nov 13, 2023Guru - Experienced User
Did you put the R8000 in access point mode?
if so, log into the dsl router and look at its attached devices page. It should have the IP address assigned to the r8000 that you can use to access it
