AWunsch
Oct 24, 2015Aspirant
Can't access R7500 router by any browser
Hi, running unter W10, browser does not get access to router - firefox (Page error) - IE10 - will show "Entry Page" - after entering name and password, next page ist blank - i am connected (gets a...
- Nov 07, 2015
Sorry, you probably need to add one more
http://routerlogin.net/index.htm and/or http://192.168.1.1/index.htm
sirsteve1968
Nov 01, 2015Apprentice
I believe you. But the question is - why is this such a touch and go issue? Works, then not, some works and then not...Where is our Netgear gurus to fix this? Very annoying and should not be causing this problem.
AWunsch
Nov 02, 2015Aspirant
Hi,
cumulative updates (KB3106932 and KB3105210) successfully installed this morning - no changes to R7500-access - still not working
- JamesGLNov 02, 2015NETGEAR Employee Retired
Hi All,
Have your tried to turn off your firewall and antivirus? May I know what Antivirus installed on your computers?
JamesGL
Community Team - sirsteve1968Nov 02, 2015Apprentice
Umm, today it decided to work w/out turning off the AV (I use Kaspersky Internet Security 2016 for Windows 10. What is really going on here? Works one day, not the next and then the next day??
- AWunschNov 03, 2015Aspirant
I am very sad, not to test this in front of my 1st message - I do run Avira Antivirus Pro at all our PC's - Windows 7 as well and this worked - deactivating Avira at W10-PC was the solution - reactivating available services step by step results in "Browser-Protection" might be the problem.
It worked with EDGE/IE/CHROM/Morzilla at my LAN-based W10-workstation, if "Browser-Protection" is OFF ! I believe, same will happen at my Laptop later on.
The question will remain, why it works at Windows7 with "Browser-Protection" and not on Windows10-Platform.
Activating of extended protocol does not show anything - the only one that appear is, that the last checked URL is "http://routerlogin.net/index.htm" - nothing else ! ! !
Who is the specialist, to solve that ? It is probably not an specific Antivirus-software problem.
- sirsteve1968Nov 03, 2015Apprentice
Sorry to sound clueless, but can you clarify what you mean by 'browser protection'? Where is that option, within your AV or browser settings? Thanks.
yes, it is one of the services within Advira, I can activate
Provided services are:
- PC-Security-Realtime-Scan
- Internet Security Firewall
- Browser-Security
- EMail-Security
- Play-Modus
Is there a way to add hardcopies - would make it much easier and more clear, even if the screens are in German.
addon: - same result at WLAN-connected W10-based Laptop - access to R7500 only, if "Browser-security" service at ADVIRA is OFF
- JamesGLNov 04, 2015NETGEAR Employee Retired
Hi All,
If you have Kaspersky you may try the following steps:
1. Open Kaspersky Internet Security and go to "Settings".
2. On the left pane, click on "Additional". Then, select "Threats and Exclusions".
3. Click "Configure exclusions".
4. Click "Add". Then, browse for your Internet browser's folder location and Select it.
5. Status of the browser should be “Active”.
JamesGL
Community Team - AWunschNov 07, 2015Aspirant
OK, for all "ADVIRA Antivirus PRO" users (Engl. definitions may be not exactly - I use German version, so it is only my translation):
- open Antivirus PRO
- switch to <Browser-Schutz> (in Engl. probably <browser-protection>)
- switch to <Ausnahmen> (in Engl. probably <exceptions>)
- include in <vom Browser-Schutz auszulassende URLs> (in Engl. probably <no browser-protection for following URLs>)
http://192.168.1.1/* (your router IP-Adress)
and/or
and R7500 will work after saving these changes, w/o deactivation browser-protection
- odinbf2Nov 11, 2015Aspirant
ich komme auch nicht in meinen router Nighthawk X4 .Natürlich kann ich deshalb auch nicht sehen welche Firmaware ich habe .Ich habe ALLES probiert ,reset kasparsky deaktiviert alle Browser .ich habe Windows 10 .Was kann man noch machen ??
- AWunschNov 11, 2015Aspirant
Vorab, ich habe "Kaperski" nicht installiert sondern AVIRA Antivirus Pro - wenn weiter oben beschriebene Procedur von James (2015-11-04 08:57 PM) nicht funktioniert, würde ich Kasperski erst inaktivieren und wenn dies nicht hilft, deinstallalieren.
Ohne Viren-Pgm hat es bei mir sofort geklappt - die richtigen Einstellungen zu finden, dauert meist länger.
mfg.
