AWunsch
Oct 24, 2015Aspirant
Can't access R7500 router by any browser
Hi, running unter W10, browser does not get access to router - firefox (Page error) - IE10 - will show "Entry Page" - after entering name and password, next page ist blank - i am connected (gets a...
- Nov 07, 2015
Sorry, you probably need to add one more
http://routerlogin.net/index.htm and/or http://192.168.1.1/index.htm
sirsteve1968
Oct 28, 2015Apprentice
******UPDATE********
Both IE and Chrome now present a login to the router. What suddenly changed??? The same thing happened on my last 7500 router (had to replace that one) and now again access is finally granted. Can a Netgear rep tell me why this may be happening? Thanks. I made NO known changes to my system running Win10.
sirsteve1968
Nov 16, 2015Apprentice
Time for another update - on my Win 10 laptop, I can still access the router, but NOT on my Win10 desktop. Both are on Windows 10 Build 10240. Why is this such an issue to keep working?
- JamesGLNov 17, 2015NETGEAR Employee Retired
Hi sirsteve1968,
Do you have the same Antivirus on both PCs?
Is it Kaspersky? If yes, please try to uninstall it and access routers page. If successful then reinstall the Kaspersky.
JamesGL
Community Team
- sirsteve1968Nov 17, 2015Apprentice
Hi James,
Yes, I have both PCs running Kaspersky and updated regularly. I'm not sure removing/reinstalling is necessary since it works fine on the laptop. Would you still recommend it even though that's the case? I mean why is it such a hard task to have this work? IT stops on its own, then when it decides to play nice, it works again. I've never worked with flakier software. Thanks for your help.
- JamesGLNov 18, 2015NETGEAR Employee Retired
Hi sirsteve1968,
Since it works on your laptop, try to remove it on the Desktop only. We have to check if this is something to do with the Kaspersky on your desktop since laptop works fine or if there are other programs that is causing the problem.
JamesGL
Community Team
