AWunsch
Oct 24, 2015Aspirant
Can't access R7500 router by any browser
Hi, running unter W10, browser does not get access to router - firefox (Page error) - IE10 - will show "Entry Page" - after entering name and password, next page ist blank - i am connected (gets a...
- Nov 07, 2015
Sorry, you probably need to add one more
http://routerlogin.net/index.htm and/or http://192.168.1.1/index.htm
sirsteve1968
Oct 25, 2015Apprentice
I have to add that I too am unable to get into my router from ANY Win 10 PC (I have 3). I can access the router just fine on Win7 AND my Mac OS which is running the latest El Capitan version. If I try to use Chome or IE, I get the page cannot be displayed or similar. I've called Netgear support and they can't figure it out. I've tried using www.routerlogin.net, 10.x.x.x and 192.x.x.x IPs w/no luck. Why is this so hard to get working? Is it an issue with Win10 which is all up to date? Please help us here! Thanks.
Retired_Member
Oct 25, 2015I have the same problem.
- JamesGLOct 26, 2015NETGEAR Employee Retired
Hi All,
Welcome to Community!
What is the firmware version of the router? Have you performed a factory reset?
JamesGL
Community Team- sirsteve1968Oct 26, 2015Apprentice
Hi James,
Yes, not only a reset, but a couple of them and I have the latest firmware ending in .94. Again, just Win10 has the issue. Does anyone know of how to get this fixed? My non-win10 PCs are fine, but Win10 is my main PC.
- AWunschOct 27, 2015Aspirant
Hi James,
same for me - W7-netbook still OK - W10-laptop and workstation obsolate - Router firmware uptodate - factory reset done with restore of latest settings
