AWunsch
Oct 24, 2015Aspirant
Can't access R7500 router by any browser
Hi, running unter W10, browser does not get access to router - firefox (Page error) - IE10 - will show "Entry Page" - after entering name and password, next page ist blank - i am connected (gets a...
- Nov 07, 2015
Sorry, you probably need to add one more
http://routerlogin.net/index.htm and/or http://192.168.1.1/index.htm
Retired_Member
Oct 25, 2015I have the same problem.
JamesGL
Oct 26, 2015NETGEAR Employee Retired
Hi All,
Welcome to Community!
What is the firmware version of the router? Have you performed a factory reset?
JamesGL
Community Team
- sirsteve1968Oct 26, 2015Apprentice
Hi James,
Yes, not only a reset, but a couple of them and I have the latest firmware ending in .94. Again, just Win10 has the issue. Does anyone know of how to get this fixed? My non-win10 PCs are fine, but Win10 is my main PC.
- AWunschOct 27, 2015Aspirant
Hi James,
same for me - W7-netbook still OK - W10-laptop and workstation obsolate - Router firmware uptodate - factory reset done with restore of latest settings
- JamesGLOct 27, 2015NETGEAR Employee Retired
I would like to know the following information:
1. Are the devices trying to access the UI connected via wired or wireless?
2. If it is wireless, is it on 2.4Ghz or 5Ghz?
3. If it is on 2.4Ghz, have you tried the 5Ghz?
4. If it is wireless, can you check the wired connection?
JamesGL
Community Team
