AWunsch
Oct 24, 2015Aspirant
Can't access R7500 router by any browser
Hi, running unter W10, browser does not get access to router - firefox (Page error) - IE10 - will show "Entry Page" - after entering name and password, next page ist blank - i am connected (gets a...
- Nov 07, 2015
Sorry, you probably need to add one more
http://routerlogin.net/index.htm and/or http://192.168.1.1/index.htm
sirsteve1968
Oct 28, 2015Apprentice
******UPDATE********
Both IE and Chrome now present a login to the router. What suddenly changed??? The same thing happened on my last 7500 router (had to replace that one) and now again access is finally granted. Can a Netgear rep tell me why this may be happening? Thanks. I made NO known changes to my system running Win10.
JamesGL
Oct 30, 2015NETGEAR Employee Retired
Hi sirsteve1968,
There was no update for R7500 but I guess your Windows 10 might have some updates which made it work. Good to know that it works now.
JamesGL
Community Team
- AWunschOct 31, 2015Aspirant
Sorry, it does not yet work - the only one that appear is the logon screen - next screen is empty !
- sirsteve1968Nov 01, 2015Apprentice
Ok. Back to NOT working again. ???
- AWunschNov 01, 2015Aspirant
Tested it this evening again -Windows10-based with EDGE/IE/Morzilla/Chrome - each browser came up with authentification screen - the next page however are different
- EDGE and IE show only screen fragments
- Firefox and Chrome gets page setup error
Internet access is working right.
For all these tests pictures attached.
