Zedechai
Feb 27, 2021Aspirant
Can't access router settings or internet after factory reset
After power outage last week, I have been getting speeds of 30 - 120 Mbps instead of the 500 Mbps I had previously. Frontier has had multiple issues in the area, so I have been waiting for them to c...
antinode
Feb 27, 2021Guru
> Model: R7000|AC1900 Smart WIFI Router
Connected to what?
> [...] v1.0.09 [...]
Not a real R7000 firmware version.
> Browsing to routerlogin.net or 192.168.1.1 error out unable to
> connect.
What's the IP address of your computer?
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual (at least). Read. Look for the
LED descriptions and "Troubleshoot".
For later, when you can talk to it again...
for Downloads. (For older versions, under Firmware and Software
Downloads, look for "View Previous Versions".) Find the kit(s).
Download the kit(s) you want. Read the "Release Notes" file for
instructions. (In the User Manual, look for "firmware", and,
especially, for a topic like "Manually Upload Firmware to the Router".)
When that fails because of a deficient User Manual, try:
Zedechai
Mar 02, 2021Aspirant
@ antinode
>Connected to what?
Frontier communications provided MoCA Ethernet Adapter Model :FCA251
>> [...] v1.0.09 [...]
As stated, I cannot get into the router settings... The above was what I thought I remembered from the night before I could have sworn that it was v1.0.9.xxx but I can't remember for sure.
IP Address was 192.168.1.2
I looked up manuals and read through these forums quite a bit.
All LEDs on the router showed white
I tried the manual firmware update but got connection refused error, or something along those lines.
I have since bought another router because I had to work from home yesterday. If I can get this one back up and running, I will use it as a backup in case I have an issue like this again.
