Zedechai
Feb 27, 2021Aspirant
Can't access router settings or internet after factory reset
After power outage last week, I have been getting speeds of 30 - 120 Mbps instead of the 500 Mbps I had previously. Frontier has had multiple issues in the area, so I have been waiting for them to c...
Zedechai
Mar 02, 2021Aspirant
I found instructions for this reboot and tried this as well. The only reboot instructions I didn't follow were the 30-30-30 because I read one person's reply that this model did not take too kindly to being restarted like that.
The Ethernet adapter is a Frontier communications provided MoCA Ethernet Adapter, Model :FCA251
It is just an Ethernet Adapter.. 1 Coax and 1 Ethernet port are the only ports on it besides power.
antinode
Mar 02, 2021Guru
> Frontier communications provided MoCA Ethernet Adapter Model :FCA251
And the other end of that is connected to what? Does its "Coax"
indicator indicate a good coax connection?
> I looked up manuals and read through these forums quite a bit.
Which "manuals"? Thanks for the helpful forum links.
> All LEDs on the router showed white
Including the USB LEDs? Or does your "All" mean something different
from my "All"? If you mean "All LEDs I care about", then I don't know
which those might be.
> I tried the manual firmware update but got connection refused error,
> or something along those lines.
None of that is a useful problem description. It does not say what
you did. It does not say what happened when you did it. As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
