bridamy's avatar
bridamy
Tutor
Jul 02, 2018
cant access router
hey all.    I cant get access to my routers page because the security question answers im giving dont match what the router says are the right responses.  I know the correct answers but its comin...
  • Blanca_O's avatar
    Blanca_O
    Jul 08, 2018
    Hi bridamy,
    How long did you press the reset button? Press and hold the reset button on the back of the router until the power led starts blinking orange. You should notice a click by pressing the reset button.
    Blanca
    Community Team
