idazco
Aug 05, 2018Tutor
Can't access router's admin UI afterupdating from 1.3.1.26 to 1.3.1.44
Updated from 1.3.1.26 to 1.3.1.44 .. I did not reset / reboot .. just ran the update which said it should take 2 minutes .. 10 minutes later after the firmware update icon was still spinning I figure...
- Aug 05, 2018
> [...] I can still get around on on the web, but the internal webserver
> of the router seems to be hung. [...]
I'd cycle the power, and see what happens.
> [...] I'm not sure its safe to reboot it and I dont want to brick it.
What real choice do you have?
https://community.netgear.com/t5/x/x/m-p/1577779
michaelkenward
Aug 06, 2018Guru - Experienced User
What does the power LED look like?
There is a manual for the R7000P somewhere at the end of this link:
>>> R7000P | Product | Support | NETGEAR <<<
Check the section Troubleshoot With the LEDs.
- idazcoAug 06, 2018Tutor
Can you really show me where in the manual this situation is covered? Because its not. RTFM answers are literally the worst.
- michaelkenwardAug 07, 2018Guru - Experienced User
No one said RTFM. I said look at the bit in the manual about the LEDs. More accurately, I asked "What does the power LED look like?"
One way to diagnose your "hung" device was to look at the state of the LEDs. Saying that it was "hung" is not enough information to go by. Or, to use your term it is "literally the worst" bit of information that you could have provided.
For future reference, the manual explains what the LEDs should look like in normal operation, and gives tips on troubleshooting when they don't look right.
For example, had you come back saying that the power LED was flashing orange, that would have been useful diagnostic data.
- idazcoAug 08, 2018Tutor
michaelkenward .. OK, you are right .. lets look at this ..
.. the LEDs were as one would have expected .. and according the manual .. "Solid white. The router is ready." .. and indeed it was behaving "ready" by in fact operating normally otherwise, and letting me "still get around on on the web"
Other than this .. the only thing out of place was the the internal web server (not the device in general, or the firware upgrade) was hung. I've seen nothing in the manual for LEDs indicating the status of the internal web server. I comprehend that, according to the manual if the power LED was "Blinking amber." it means "The firmware is upgrading" ... but since it was not I concluded that the firmware upgrade process was not hung.
Therefore as I said, only .. and specifically .. the internal web server was hung.
