idazco's avatar
idazco
Tutor
Aug 05, 2018
Can't access router's admin UI afterupdating from 1.3.1.26 to 1.3.1.44
Updated from 1.3.1.26 to 1.3.1.44 .. I did not reset / reboot .. just ran the update which said it should take 2 minutes .. 10 minutes later after the firmware update icon was still spinning I figure...
  • antinode's avatar
    Aug 05, 2018
    > [...] I can still get around on on the web, but the internal webserver
    > of the router seems to be hung. [...]
       I'd cycle the power, and see what happens.
    > [...] I'm not sure its safe to reboot it and I dont want to brick it.
       What real choice do you have?
          https://community.netgear.com/t5/x/x/m-p/1577779
