idazco
Aug 05, 2018Tutor
Can't access router's admin UI afterupdating from 1.3.1.26 to 1.3.1.44
Updated from 1.3.1.26 to 1.3.1.44 .. I did not reset / reboot .. just ran the update which said it should take 2 minutes .. 10 minutes later after the firmware update icon was still spinning I figure...
- Aug 05, 2018
> [...] I can still get around on on the web, but the internal webserver
> of the router seems to be hung. [...]
I'd cycle the power, and see what happens.
> [...] I'm not sure its safe to reboot it and I dont want to brick it.
What real choice do you have?
https://community.netgear.com/t5/x/x/m-p/1577779
antinode
Aug 05, 2018Guru
idazco
Aug 06, 2018Tutor
Hiya antinode. Ya .. that's basically what I was thinking ... there's no other choice ... so I took a deep breath .. and rebooted it ...
Thankfully, the worst thing that happened is that I had to reset the master password, but everything else worked just fine.
I swear .. one day I'll build another iptables FW for my network. This shot-in-the-dark nonsense is too un-nerving.
