idazco
Aug 06, 2018Tutor
Can't access router's admin UI afterupdating from 1.3.1.26 to 1.3.1.44
Updated from 1.3.1.26 to 1.3.1.44 .. I did not reset / reboot .. just ran the update which said it should take 2 minutes .. 10 minutes later after the firmware update icon was still spinning I figure...
- Aug 06, 2018
> [...] I can still get around on on the web, but the internal webserver
> of the router seems to be hung. [...]
I'd cycle the power, and see what happens.
> [...] I'm not sure its safe to reboot it and I dont want to brick it.
What real choice do you have?
https://community.netgear.com/t5/x/x/m-p/1577779
michaelkenward
Aug 08, 2018Guru - Experienced User
idazco wrote:
Therefore as I said, only .. and specifically .. the internal web server was hung.
What is this "internal web server"?
The last time I looked at my R7000P it didn't have one of those.
antinode
Aug 08, 2018Guru
Presumably, the router's management web server.
I'd bet that it does, except when using a peculiarly eccentric
definition of "web server".
Back in the real world...
Sadly, you are dealing with a fellow who seems to believe (adamantly)
that a web site or a web server is only a web site or a web server if
it's _not_ in your router. For example:
https://community.netgear.com/t5/x/x/m-p/1615918
https://community.netgear.com/t5/x/x/m-p/1466400
https://community.netgear.com/t5/x/x/m-p/1373383
[and so on, and on, and on, ...]
As you can see, attempts at rational persuasion have, so far, been
unsuccessful.
