gusperrysmom
Dec 21, 2016Aspirant
Can't access the Router Login page after doing factory reset.
Router: Nighthawk R8000 Version: 1.0.3.26 OS: Windows 10 WiFi access I have been having intermittent connection problems and Geek Squad said it was a router issue and not a computer (Window...
- Dec 22, 2016
Hi gusperrysmom,
If you have a kaspersky antivirus, you might want to check the KB article below.
http://kb.netgear.com/30012/Unable-to-access-router-management-page-with-Kaspersky-installed
Dec 21, 2016Guru - Experienced User
It could of course be an ISP problem too.
You could try something like the trial version of PingPlotter and let run ping tests in the background. If your modem has a web admin page, you should be able to ping that, and that will show you any issues between the PC and the modem (e.g., the router). You can also ping some other internet hostname simultaneously (for instance geeksquad.com), and compare the results.
The usual IP address for your router would be 192.168.1.1, not 163.
You can find out your PC's "gateway address" using the guide here: http://www.howtogeek.com/233952/how-to-find-your-routers-ip-address-on-any-computer-smartphone-or-tablet/ That is your router's local IP address.
gusperrysmom
Thanks, Stephen. Yes. That is a typo on my part. 192.168.1.1 is the IP address for the router.
- StephenBDec 21, 2016Guru - Experienced User
Probably you should solve the login page issue before you go back to the internet connection problem. You might need to try a second reset.
- gusperrysmomDec 21, 2016Aspirant
Yes. The login page issue is what I'm trying to solve and I'm afraid PingPlotter is way beyond my level of understanding.
- JamesGLDec 22, 2016NETGEAR Employee Retired
Hi gusperrysmom,
