gusperrysmom
Dec 21, 2016Aspirant
Can't access the Router Login page after doing factory reset.
Router: Nighthawk R8000 Version: 1.0.3.26 OS: Windows 10 WiFi access I have been having intermittent connection problems and Geek Squad said it was a router issue and not a computer (Window...
- Dec 22, 2016
Hi gusperrysmom,
If you have a kaspersky antivirus, you might want to check the KB article below.
http://kb.netgear.com/30012/Unable-to-access-router-management-page-with-Kaspersky-installed
gusperrysmom
Thanks, Stephen. Yes. That is a typo on my part. 192.168.1.1 is the IP address for the router.
Dec 21, 2016Guru - Experienced User
Probably you should solve the login page issue before you go back to the internet connection problem. You might need to try a second reset.
- gusperrysmomDec 21, 2016Aspirant
Yes. The login page issue is what I'm trying to solve and I'm afraid PingPlotter is way beyond my level of understanding.
- JamesGLDec 22, 2016NETGEAR Employee Retired
Hi gusperrysmom,
- gusperrysmomDec 22, 2016Aspirant
Well JamesGL ... you were absolutely right. I ultimately had to uninstall Kaspersky to get to the Router Login page. Kaspersky and Chrome just do not like each other. Guess I'll try working with Kaspersky now. Wish me luck! Thanks so much!!!
