lest77
Jul 21, 2017Aspirant
can't access Traffic meter
In the product guide there is a section on page 170 for "Start the Traffic Meter Without Traffic Volume Restrictions". The instructions tell you to login to the router, go to the Advanced tab and the...
- Jul 26, 2017
Hi lest77,
If you can access the router's UI, go to advance settings and look for wireless mode or AP mode. Uncheck it.
JamesGL
Jul 24, 2017NETGEAR Employee Retired
Hi lest77,
The router might be set to AP mode. When router is set to AP mode, other features will not be available(greyed out).
- lest77Jul 25, 2017Aspirant
Thanks for your response. How do I turn off AP mode?
- JamesGLJul 26, 2017NETGEAR Employee Retired
Hi lest77,
- JamesGLJul 31, 2017NETGEAR Employee Retired
Hi lest77,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
