Kdawg19
Dec 10, 2021Aspirant
Can't access wifi at all, R6120 — AC1200 Dual Band WiFi Router
Model: R6120 — AC1200 Dual Band WiFi Router My Wi-fi was working flawlessly on my computer and phone, but for some reason it stopped working on the smart TV. I tried to restart it to make it work on...
michaelkenward
Dec 11, 2021Guru - Experienced User
My Wi-fi was working flawlessly on my computer and phone, but for some reason it stopped working on the smart TV. I tried to restart it to make it work on the TV, and I updated it and I may have hit the reset-button. Now I can not do anything with it. If I log in to my nighthawk app, I can't do anything because I'm not connected to the network. I have tried eveything, turning it on and off again, disconnecting the cords and putting them back in, but it just seems that nothing seems to be working. Has anybody exprienced anything similar?
Is all the wifi bust? Or do you mean that you can't get the TV to connect to the wifi?
When everything else is working properly, this is usually down to the TV. The last thing you should so is to start messing around with the wifi.
The router just provides wifi. It is then down to the TV to do its thing.
The TV's controls are the place to look.
Kdawg19
Dec 13, 2021Aspirant
At first it was just the TV, but now the wif-fi itself does not work. The internet works (ethernet cable connected to the modem) but not the router
