Sharvy
Dec 11, 2016Aspirant
Can't assign printer an ip address
I'm trying to configure a wd-3620 Epson printer. I don't have an Ethernet port so I can only connect wirelessly. In attached devices, Nighthawk sees the printer, and sees the printer's MAC address, b...
- Dec 19, 2016
I recommend that you set a STATIC IP address ON the printer using the printers menu control panel. If your NR router is using 192.168.1.### address pool then change the printers address to 192.168.1.36 or .20. I recommend changeing the routers IP address pool from 192.168.1.2 thru .254 instead to 192.168.1.100 thru .200. Then you can assign Static IP addressed to devices outside of the IP address pool. Cameras, NAS and printers can be set for static IP addresses since they dont' need much or if any router management or controls. .100 thru .200 still leaves you pleanty of addresses for Revervation IP addresses.
Sharvy
netwrks wrote:It sounds like it did not authenticate using wireless passphrase...
Well I also set it up from the printer side: the printer sees the SSID and I entered the password. Also both my iphone and laptop see the printer and I can print over the wifi. Apparently it's working through Bonjour. But it bothers me that I can't assign it a network ip address.
ElaineM
Dec 14, 2016NETGEAR Employee Retired
It might be just a glitch in the GUI.
Do the printer get an IP address when you check its settings?
I connected my printer and it shows the IP of 192.168.1.4.
By the way, which signal is your printer connected to (2.4GHz or 5GHz)?
Have you tried doing a factory reset on the router?
- SharvyDec 14, 2016Aspirant
Thanks Elaine.
When I look at Attached Devices I get the same chart. Every field for every device is filled in, except for the printer in the 2.4GHz category. That has its correct MAC address (and the status is Allowed) but the IP Address field just has a simple dash, no numbers. All of the other 7 devices have a displayed IP address. I tried switching to the 2.4GHz SSID (from the 5GHz) but it doesn't help. I really don't want to do a reset, since I fiddled around with the channels and made some other custom settings. The printer is connecting and working over my Bonjour network, but it's still bothersome that I can't get the printer to display an IP. I assume there must be some conflict, but I can't tell what it is. When I go to the printer to display its network settings, it says it has the IP address 192.168.0.105. Hmmmm .... that's not in the range of the DHCP server in LAN setup. That range is 192.168.1.2 through 192.168.1.254. So maybe explains why it's not showing up. But I tried adding a reserved DCHP address 192.168.1.9 with the the printer's MAC address, making sure to hit "apply", but that didn't help.
- ElaineMDec 14, 2016NETGEAR Employee Retired
That's strange if it has a different IP range.
It should have the 1.x range unless it's connected to another wireless device.
Do you have another wireless router in your network? It could be your modem that might be broadcasting the same SSID.
- SharvyDec 15, 2016Aspirant
ElaineM wrote:That's strange if it has a different IP range.
Well the router config page shows the modem as: (that's the MAC address of the modem) So the IP is dynamically assigned by the ISP
MAC Address :1B:6D IP Address 45.xx.xxx.138 Connection DHCP IP Subnet Mask 255.255.224.0 Domain Name Server 2xx.xx.xx.61
2xx.xx.xx.62****************************************************************************************************************************************
But when I access the printer configuration page I see. So I don't know why
Printer Name :
EPSON46FConnection Status :
Wi-Fi-72MbpsSignal Strength :
ExcellentObtain IP Address :
ManualIP Address :
192.168.0.105Subnet Mask :
255.255.255.0Default Gateway :
192.168.0.1DNS Server Setting :
ManualPrimary DNS Server :
192.168.0.1Secondary DNS Server :
DNS Host Name Setting :
ManualDNS Host Name :
EPSON46184FDNS Domain Name Setting :
ManualDNS Domain Name :
Register the network interface address to DNS :
DisableProxy Server Setting :
Do Not UseIPv6 Setting :
EnableIPv6 Privacy Extension :
DisableIPv6 Address :
::/0IPv6 Address Default Gateway :
::IPv6 Link-Local Address :
fe80::xxxxxxxxxxxI can't see that the modem has anything to do with SSID's assigned by the router. So I don't know why the printer
has a Primary DNS Server as 192.168.0.1 or the printer is assigned 192.168.0.105. Are those assigned by Epson as a factory default setting? Can I change it so it shows up in the router config page?
Thanks,
Sharvy
