aprilt26
Feb 16, 2022Follower
Can't connect ethernet
I cannot connect the router to my ethernet connection in one office. The desktop says make sure ethernet plug is plugged in. It is. Tried several ethernet cables and also had the outlet tested and...
Feb 16, 2022Guru - Experienced User
Test a wired PC connected to each port on the router with a good quality known working LAN cable. CAT6 is recommended.
Netgear has set up a community forum specifically for Smart WiFi Router products:
https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-general
Thank you
