aprilt26
Feb 16, 2022Follower
Can't connect ethernet
I cannot connect the router to my ethernet connection in one office. The desktop says make sure ethernet plug is plugged in. It is. Tried several ethernet cables and also had the outlet tested and...
Feb 16, 2022Guru - Experienced User
What actual router do you have?
Is it the C6300 from your connection?
Is the C6300 connected via coax to your ISP?
and its activated?
Or how are you connecting it exactly? You put you're connecting to the ethernet in your ofice and you've had the outlet tested. If you have the C6300 is a modem/router combo device. Its not a router by itself.
