DanielHey
Jun 17, 2017Aspirant
Can't connect my Nighthawk R7000 to the internet
Hi all, Just needed help as I have tried putting my netgear online through my wall and through and ethernet cable straight to my computer. When plugging it into the wall, my phone regognises it a...
- Jun 18, 2017
Sorry should have posted this before but I have worked out what was wrong. As part of my wall had lost power, I just had to manually connect my NightHawk to the actual router so it's working now, thank you for the reply. I will just accept my comment as the solution to close this thread.
JamesGL
Jun 18, 2017NETGEAR Employee Retired
Hi DanielHey,
If you connect your computer directly to the wall, will you have internet connection? If yes, what is the IP address?
DanielHey
Jun 18, 2017Aspirant
