stranghappening
Dec 21, 2016Aspirant
Can't connect through switch
I have a witch that connects to one of the LAN port on the router and until a few days ago all devices on the switch was able to get a valid IP from the router. Now, none of my devices are able to co...
- Dec 22, 2016
Thanks everyone for the reply. I have finally found the issue that was causing the problem. It seems that the Directv Whole-home connector was causing the problem. I had only been debugging the switch and router since all the symptoms were related to them. Not sure what update was pushed, but the problem resolved itself once I removed that from my LAN on the router. It doesn't make sense on why it would cause a problem.
As for all the suggestions made by everyone, I did try all of them prior to posting even with powering each item in sequence (router, switch, computer).
Dec 21, 2016Guru - Experienced User
Did you also remove/restore power to the switch?
