stranghappening
Dec 21, 2016Aspirant
Can't connect through switch
I have a witch that connects to one of the LAN port on the router and until a few days ago all devices on the switch was able to get a valid IP from the router. Now, none of my devices are able to co...
- Dec 22, 2016
Thanks everyone for the reply. I have finally found the issue that was causing the problem. It seems that the Directv Whole-home connector was causing the problem. I had only been debugging the switch and router since all the symptoms were related to them. Not sure what update was pushed, but the problem resolved itself once I removed that from my LAN on the router. It doesn't make sense on why it would cause a problem.
As for all the suggestions made by everyone, I did try all of them prior to posting even with powering each item in sequence (router, switch, computer).
VE6CGX
Dec 21, 2016Master
Basic switches are dumb Switch itself is gone bad or if it uses wall wart, it could've gone bad.
- StephenBDec 21, 2016Guru - Experienced User
VE6CGX wrote:
Basic switches are dumb.
Sometimes "rebooting" the switch can help. Even a basic switch builds and maintains a switching table as it learns which mac addresses can be reached on each switch ports. They have no user interface controls, but that doesn't mean they are dumb.
I don't think this switch has actually failed though, since it did work when the poster connected it to another router.
