virtualgeorge
Sep 08, 2022Aspirant
Can't connect to 2.4 but 5g still works?
I have centurylink and a C2000T modem. I have a Nighthawk 7450 dual band that has been working fine for years but after power outage I suddenly can't connect any of my devices to the 2.4 network. See...
michaelkenward
Sep 09, 2022Guru - Experienced User
virtualgeorge wrote:
I have centurylink and a C2000T modem. I have a Nighthawk 7450 dual band that has been working fine for years but after power outage I suddenly can't connect any of my devices to the 2.4 network. Seems like I see errors on connections using 5g but it still seems to work.
I assume that this Nighthawk 7450 is a router of some sort. (That isn't a model number that I recognise.)
Power cuts usually take out both the modem and the router on a network. When the power comes back on, they may start up in the wrong order, with the router starting before the modem is ready. That means that they get confused about which is in charge.
It may help to reboot the whole network in the right order.
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
- virtualgeorgeSep 09, 2022Aspirant
Thought I posted a link to the router R7450
https://www.netgear.com/home/wifi/routers/r7450/
Thanks, I will try the restart order you mentioned. I did that but left a couple computers turned on. This has happened a few times over the years when the network didn't restart right after a power outage and after updating the firmware on my dual band router it comes up. However, prob not a firmware issue but just rebooting that router last helped like you suggested.Thanks for all the info!!
