Mrcorvettegolfe
Mar 30, 2022Aspirant
Can't connect to 5g
I can connect to my router netgear92 but I can't connect to 5G. This is with any device. On the Ipad it says "Can't obtain authorization" on other devices it just says can't connect.
Mar 30, 2022Guru - Experienced User
You have the r7000P?
What firmware is on it?
What modem/gateway is it connected to?
have you checked your wireless password settings?
Mrcorvettegolfe
Apr 11, 2022Aspirant
You have the r7000P? Yes it is.
What firmware is on it? V1.3.2.134-10.1.66
What modem/gateway is it connected to? Arris TM1602 cable modem
have you checked your wireless password settings? Yes it is the same as the 2gz.
It does baffle me. I can't connect either IOs or android mobile devices.
I have restarted both the modem and the router several times.
- plemansApr 11, 2022Guru - Experienced User
Have you tried a simple factory reset on the router and reinstall?
Push and hold reset for 7-15 seconds while powered on.
