ToussiaintOps
Aug 15, 2022Aspirant
Can't connect to admin, reset hasn't worked
My boss handed me a router to connect to from his home office. Trying to repurpose it here in the work office. I connected the router, a NightHawk X6S R7900P. I logged into routerlogin.net and enter...
Aug 15, 2022Guru - Experienced User
Be sure you clear out the browser caches before entering the routers web page.
Try pressing the rest button for 10-15 seconds in back then release.
Enter in 192.168.1.1 in to a browser.
Try MS Edge, IE, Firefox or Opera browser.
ToussiaintOps
It is still providing the same error. I cleared the cache for Microsoft Edge and tried that, and it didn't work. I downloaded Firefox and tried that, and it was the same result. I also long reset as you suggested.
- ToussiaintOpsAug 15, 2022Aspirant
I have to wonder...
there is another nighthawk router set up nearby, with admin but a different password.
Could the presence of a second night hawk router be interrupting the setup of this one by any chance?
- FURRYe38Aug 15, 2022Guru - Experienced User
Are you ethernet connected to the router with one PC? Ethernet would best to avoid any wifi confusion.
