scorpiorc10's avatar
Dec 29, 2015
Cant connect to EA servers SW BattleFront R7000
So I have been on the phone with netgear support for 2 hours and still havent been able to figure it out.
I have called EA support and configured all ports for port forwarding they told me too.
I called my ISP and they checked everything and I am good 350mbps down and 30mbps up
When I bypass the router and connect the computer directly to the cable modem I connect to the EA servers with out any issues.
NAT is set to open and UPnP is enabled.
Please help
  • RMA the router and then called ea support and verified all the ports for port forwarding
    • scorpiorc10's avatar
      scorpiorc10
      Tutor
      latest
      R7000 Firmware Version 1.0.6.28
      RMA got a new and it is working now.
      • kristir's avatar
        kristir
        We are having the same issue -- could you explain how you fixed this?  Our router connects fine for everything except this game.
